New Product: ROCKSTAR hitch mounted mud flaps
2 Attachment(s)
You’ve probably heard of our ACCESS® Roll-Up Covers and SnowSport® Snow Plows, but I’ve got a new product here from Agri-Cover, Inc.
These are the ROCKSTAR™ Hitch Mounted Mud Flaps. Attachment 3557 First off, the rubber on these mud flaps is made to take a beating. The wide flaps are half an inch thick because we want them to keep boats, campers and other trailers safe from rock damage. They have a smooth finish to resist ice and mud buildup. Then there’s the frame, which is laser-cut with a model-specific fit for Chevrolet, Ford, GMC or Ram pickups. It’s made from aluminum with stainless-steel hardware to resist corrosion, and you can get it your choice of smooth mill finish (above) or diamond plate. Attachment 3558 This whole assembly is bolted around your hitch’s ball mount, while its built-in stabilizer plate keeps it level with the bumper. After you’ve installed the flaps, you can disconnect the ball mount and quickly store the whole assembly until the next time you need to tow. The convenient frame openings give you access to connect trailer wiring, and the rubber-capped spacers help with aligning the pin. The custom frame and flaps include exhaust holes designed to work with Dodge OEM dual exhaust ports. A heat shield is included with Chevy/GMC 2500 and 3500 truck models and is available for other applications where the exhaust is directed toward the flaps. We’ve also made this system ready for owners of trucks with suspension lifts or larger tires. They can choose the Trim to Fit Flap option, which comes with extra-long rubber flaps that can be trimmed to a custom length. The ROCKSTAR™ hitch-mounted mud flap system comes with a one-year warranty. If you want to see more details, check out our website. |
