Rally Style Grille with LED Driving Lights is Now Available at CARiD
Hi everyone, today we want to introduce you our new product - XE Series LED Black Mesh Main Grille Kit. It's a custom grille with built-in driving lights that will be perfect for the fans of Rally style and those who want to improve the light output of their Canyon. Thanks to the fully adjustable Hi/Low Ocular LED Grille lighting system, each XE Series grille is equipped with, you'll be able to aim the light beams exactly where you need. Each light adjusts individually. To provide your GMC Canyon with a clean, framed front end look, GrillCraft grilles will easily fit in your OE grille shell. The installation can be performed as a DIY project using our plug and play wire harness. Includes: * Main grille * 4 LED lamps * Wiring harness Features: * Price: $499.00; * 1-Piece; * Manufactured; * Installation type: insert; * Grille kits are vehicle specific. Installs into OE grille shell; * Plug and play wire harness; * Each light adjusts individually; * Drilling for mounting screws is required; * Grille shell center section must be cut out; * Uses existing OE grille surround; * Emblem is not included. All emblems are removed and reused from the OE grille assembly; Grillcraft - 1-Pc XE Series LED Black Mesh Main Grille Kit at CARiD https://www.carid.com/grillcraft/1-pc- xe -series-led-black-mesh-main-grille-kit- mpn -gmc2037b-xe4.html https://www.carid.com/images/for-for...forums-600.jpg https://www.carid.com/images/for-for...forums-600.jpg https://www.carid.com/images/for-for...forums-600.jpg https://www.carid.com/images/for-for...forums-600.jpg https://www.carid.com/images/for-for...forums-600.jpg Equip your truck with so far one the best and most functional aftermarket grilles in terms of light output and appearance, order your custom fit GrillCraft Main Grille Kit from CARiD today! |
| All times are GMT -5. The time now is 05:44 AM. |
