-   New Member Area (https://www.truckforums.com/forum/new-member-area-4/)
-   -   MOTORVATOR TBS (https://www.truckforums.com/forum/new-member-area-4/motorvator-tbs-4004/)
07 6.0 VMAX Aug 6, 2007 08:15 AM
MOTORVATOR TBS
I just bought my truck doing a little at a time ,but i ran into a prob. i tried putting a motor vator TBS & the copmuter started throwing all kinds of codes truck woudn't run 1 of the codes was loss of power any one encounter this before only thing i can come up is that this NBS 07vmax motor could possibly have a bigger throttle body on it & the spacer i tried was for different 6.0 throttle body.Any info. appreciated.
72charger Aug 6, 2007 01:45 PM
RE: MOTORVATOR TBS
That's odd. Did you take it off and put it back together to see if it quit? Don't know why it would have done that unless you didn't mount it up right and had an air intake leak which would have made the ECU fuss, kick, and scream.
07 6.0 VMAX Aug 6, 2007 03:25 PM
RE: MOTORVATOR TBS
Yes i confirmed no vaccum leak hope it's not just that my trucks comp.is not going to allow me to install one.
superddd Aug 6, 2007 10:07 PM
RE: MOTORVATOR TBS
I'm a few years away, but I didn't have any computer issues. Is the TBS the same bore size as your TB? You may havean overlap somewhere causing a vortex and screwing up the airflow in the manifold. Good Luck.
chevy112488 Aug 6, 2007 11:09 PM
RE: MOTORVATOR TBS
did you plug everything back in? i put mine in and i forgot to plug some of the wires back into the throttle body... truck wouldn't start...
72charger Aug 6, 2007 11:41 PM
RE: MOTORVATOR TBS
LOL:D
07 6.0 VMAX Aug 7, 2007 06:59 AM
RE: MOTORVATOR TBS
Thanks for the info. i guess it is possible to have had some overlap but i tried it several times & it did the same thing evrrytime my next step will be to mic the spacer & throttle body.I've had TBS's on all my other trucks w/out any trouble.
