u-joint
I'm needing info on how to remove/replace the u-joints on a 92 Z71. I've replaced the tranfer case and figured that this is a great time to replace the u-joints. Only problem is that I don't know how to remove the joints from the axles.
RE: u-joint
First very important!! mark driveline so you get proper alignment when you put back together, otherwise you may pick up a vibration. Unbolt from rear axle, get yourself an old socket( one thats already in bad shape, preferably a deep well if you don't have a press) You can hammer these suckers in and out using the socket and a block of wood.line up your marks ...reinstall
| All times are GMT -5. The time now is 08:32 AM. |
