-   Off Road (https://www.truckforums.com/forum/off-road-44/)
-   -   Largest tire sizes for each make (https://www.truckforums.com/forum/off-road-44/largest-tire-sizes-each-make-9342/)
texaskicks Mar 5, 2009 08:56 AM
First off I will admit some lazyness here, as I don't want to filter though every vehical forum.
So what I want to know is what is the largest tire size or outside diameter for every truck make over the last 15 years or so. I ask that the exact model (year/make/model)is listed and what modification takes to fit that tire size (stock/50% tortion tweek/xx'' suspesion/xx" body ect.)
For example:
1998 Silverado 2500 50% torsion tweek = 285/75-16 no rubbing.
The reason I ask is that I could not find one place that contained this type of info for each make/model. Also I want to by a "new to me" truck and put on the largest rubber with the least amount of lift.
charry89 Mar 13, 2009 11:38 PM
all the lifts that say you will be able to fit so and so tire is never correct! they say it takes a leveling kit to fit 33's on an 02 z71 but my truck fits them fine stock wit a small torsion crank. im currently puttin a 3" body lift and will be able to fit 35's wit plenty of room!
jbracefan1977 Mar 14, 2009 03:33 AM
Originally Posted by lawheelsdirect (Post 42598)
There is no such list that I know of. However most lift kits will tell you what size tires will fit once the lift is installed if that helps.
agreed no list exist, do you think it would help to have one on this forum though? just a thought...
