TRUCK PTO ISSUE
Old Apr 10, 2008 | 12:41 AM
yym_5433's Avatar
Default TRUCK PTO ISSUE
Could someone tell me the diference between Engine PTO and Transmission PTO, such as the performance, price, purpose. Thanks.
Old May 1, 2008 | 09:36 PM
richbaker's Avatar
Default RE: TRUCK PTO ISSUE
"A power take-off (PTO) is a splined driveshaft, usually on a tractor or that can be used to provide power to an attachment or separate machine. It is designed to be easily connected and disconnected. The power take-off allows implements to draw energy from the tractor's engine. Semi-permanently mounted power take-offs can also be found on industrial and marine engines. These applications typically use a Cardanshaft and bolted joint to transmit power to a secondary implement or accessory. In the case of a marine application, such shafts may be used to power fire pumps."
_______________________
Full Throttle at Autopartswarehouse
Dachshund
Mar 27, 2015 10:58 AM
yym_5433
Apr 10, 2008 10:34 AM
Toolman
Jan 13, 2008 06:07 PM
chlngr1970
Dec 20, 2005 03:24 PM
mellowyellow598
Jul 14, 2005 02:37 PM
