97 chevy z71 brickwall
Hey guys,
Got an issue with my ride and am at a standstill. First started with a check engine light which indicates a miss in cyl 3 and 4. Changed out dist cap, rotor, wires, and plugs and still had the light and symptoms of miss/high(1000+ rpm consistently) idle. Seems like a slight miss can be heard from the exhaust as the vehicle is running (no blue or smoky exhaust but leaves a nasty carbon build-up on my trash can) and vehicle stalls when oil cap is removed. After ~200 miles, I checked the plugs again and 3 and 4 were fouled pretty bad with an ashy build-up and possible slight oil contamination. Almost all plugs had slight oil on threads but not noticed on firing mech. and not fouled(except 3 and 4). New fuel pump, o2 sensor, PCV with no improvements. Possible related symptom of small radiator leak/crack(unsure) which i attempted to fix with a J&B liquid stop leak. Radiator began purging the coolant system through overflow tank until i flushed the tank drain to radiator and it seemed to have slowed the purging. I believe the stop leak settled in the overflow tank and radiator was unable to retrieve coolant from tank. Any advice on what the culprit is will be greatly appreciated. Next step is compression test...wish me luck. |
Originally Posted by 97zsilvy
(Post 59103)
Hey guys,
If the truck hasn't already had them changed I would change the intake gaskets. They are famous for failing. While the intake is off I would inspect the spider injector in there for cracks or brittle lines. Good luck!
| All times are GMT -5. The time now is 03:42 AM. |
