Report Concerns, Make Suggestions, & Get Help Using The Forum A.K.A. Feedback Section Have questions, comments, or concerns about the website, post them here! NO TECH POSTS
Get the best engine for your truck – tips
Old 01-18-2011, 07:10 AM
auto123's Avatar
Default Get the best engine for your truck – tips
Engines are the parts due to which your automobile is going to start and run. If it is good enough, then your vehicle will run. It is not necessary that new branded engines are good enough to work; even used engines are good provided they are selected properly. Few tips are given when you are buying truck engine.
A thorough inspection should be performed when you are buying used truck engine. This inspection will lead to decide the price of the vehicle based on its condition. This type of inspection helps to decide whether you should buy or not?
There are few check points that should be inspected. Before starting physical inspection you should enquire and get the basic details of the truck like
1. Recalls or service program of the truck
2. Any warranties on vehicle or its part still applicable
3. Mileage should be checked and as they can give idea about its usage and depreciation. One should
also verify mileage against warranty claims.
http://subscribers.wardsauto.com/images/2007/10/detroit-diesel-dd15-heavy-duty-engine.jpg
The external condition checking points can be considered as primary as they give us the approximate usage and its condition. The internal condition checking points are very critical as they help us to know the exact usage, problems in the truck engine and other precision parts of the truck.
If you some more tips then you can share withy me.
auto123
03-09-2011 09:11 AM
GMCSierraFan
03-01-2011 10:46 PM
auto123
09-20-2010 12:35 AM
03Chevrolet1500
02-26-2008 10:00 PM
TONY STAR
01-12-2007 03:27 PM
Quick Reply: Get the best engine for your truck – tips
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
