Get best fog lamp for your truck … tips..
Used fog lamps
It is very much risky when you replace fog lamps if you are not trained properly for it. Follow the below tips for fixing the fog lamps newly or a replacement..: 1. Buy useful materials (available at the end of these steps). 2. Remove the lamps from box and note their ampere rating. Wait and get a knob of appropriate rating. If such knob of equal or high rating can’t be found, then you will need to rely on them. 3. Use bracket to place them in preferred place. 4. Select a proper position on the Truck to place the knob for lamps. 5. Place the knob on the vehicle. 6. Join the Light circuit to the “Load” portion of the relay. 7. Sprint wire from power resource supply to one of the relay’s load terminals. Join the relays to other load terminals to the lamps clandestine. Join the residual connection on the lamp to one end of connection to the other lamp. Join second lamps residual connection to the negative part of power resource. 8. Join the knob. Sprint wire from a power resource to one of the main terminals on the relays. 9. Join the other terminals to the knob. Join the residual knob terminal to the negative of power resource. 10. Install bulbs in lamps. 11. Start vehicle and test now. If chosen resource fuse lights, change and try connecting to another resource. 12. Continue if all works in good condition. Check the connections that are made since starting. 13. Cover all connections with electrical tape to assure water tautness. 14. Close hood and start using it. http://www.google.co.in/imgres?imgur...Disch:1&itbs=1 http://www.google.co.in/imgres?imgurl=http://www.best-b2b.com/userimg/658/668-2/fog-lamp-for-truck-761.jpg&imgrefurl=http://www.best-b2b.com/Sub-cat/658/668/car-light-auto-mirror_58.html&usg=__wyAVHYU9DgVfppnPBuTo87jRSqQ=& h=300&w=432&sz=18&hl=en&start=12&sig2=RUkd3JEHOLTc XE-dK28Hdw&zoom=1&tbnid=MiV6LNPE0UNLjM:&tbnh=127&tbnw =169&ei=T9c2TeitMIWgvQO-25yYBA&prev=/images%3Fq%3DUsed%2Bfog%2Blamps%2Bfor%2Btruck%26hl %3Den%26sa%3DG%26biw%3D1024%26bih%3D578%26gbv%3D2% 26tbs%3Disch:10%2C585&itbs=1&iact=hc&vpx=605&vpy=2 75&dur=998&hovh=187&hovw=270&tx=124&ty=103&oei=Hdc 2TaLSCobMuAOynZTcAw&esq=14&page=2&ndsp=15&ved=1t:4 29,r:13,s:12&biw=1024&bih=578 |
Hey good tips thanks guy
