-   Report Concerns, Make Suggestions, & Get Help Using The Forum (https://www.truckforums.com/forum/report-concerns-make-suggestions-get-help-using-forum-43/)
-   -   Tailgate not opening (https://www.truckforums.com/forum/report-concerns-make-suggestions-get-help-using-forum-43/tailgate-not-opening-16619/)
Iceman777 May 17, 2011 06:48 PM
I have a 95 GMC K1500 and the tailgate will not open. What do I need to replace?
Thanks for any help
Mr_Shamrock May 17, 2011 06:51 PM
Most of the time it is just the handle. If you remove the bezel around the handle you will see a metal arm with a 90 degree bend coming from both sides. Sometimes a little lube will get it working. You can squeeze those 2 arms together to open the tailgate.
Iceman777 May 18, 2011 04:24 PM
Yeah I have taken the bezel off before. Each cable gets pulled, but the left side gets pulled more than the right?
Mr_Shamrock May 18, 2011 07:25 PM
You need a new handle, but you can take the handle out and try bending the tabs that pushes down on the part that the 2 arms attach to. Your right one is up further than the left one. This has only worked a couple times for me (I have repaired and replaced many). The handles are cheap so I would probably go that route and call it done.
Iceman777 May 19, 2011 05:37 PM
Ok thanks
