1992 GMC Sierra XC, 5.7, K2500 fuel troubles.
Old Jul 19, 2018 | 10:52 AM
Provo3's Avatar
Default 1992 GMC Sierra XC, 5.7, K2500 fuel troubles.
I recently acquired a 92 Sierra XC, sitting for a couple of years. Boby too solid to send it to the crusher, would like to get it back on the highway. Started and ran rough with a jump when I towed it home, drained old gas, replaced fuel filter and put fresh rizz in, fired up and ran. Rich albeit, test drive attempt ended with a tow home. No fuel! No power at fuel pump fuse, powered up fuse, jumped relay no fuel! I'ma gonna go nuts! Please help!
1992 GMC Sierra XC, 5.7, K2500, 198kmi
Old Jul 28, 2018 | 10:18 PM
Jackedup92's Avatar
Oil pressure switch on back of motor behind distributor can cut power to fuel pump if it doesnt register any oil pressure... when u turn the key on do u hear the pump priming up? Also relay on firewall under black box are notorious for going bad or connections being corroded. If all else fails go to your tank and check for power at the plug to the pump..
Sanddraggin
15
Feb 4, 2017 09:02 AM
Eskimojim
Nov 19, 2012 08:44 AM
NullHead
May 19, 2012 12:53 AM
88 gmcguy
Dec 29, 2010 07:55 AM
neR10
Jun 26, 2007 05:06 AM
