AC does not work on 1,2,3, or 5
Old Jun 15, 2013 | 07:25 AM
omrios79's Avatar
Default AC does not work on 1,2,3, or 5
It only works on 4. Is this still a blower motor resistor issue?
Thanks!
Old Jun 15, 2013 | 01:15 PM
NullHead's Avatar
Get out your test light and make sure that your resistor is getting juice to the required pins in the connector.
What year truck do you have?
Old Jun 15, 2013 | 08:47 PM
Yap I would say it's a resistor problem
Depending on your truck... You may have to replace the blower motor cause the resistor is in the motor housing. Or you may get lucky and the resistor is external
Old Jun 17, 2013 | 08:23 PM
NullHead's Avatar
As easy as it is to say it's the resistor, the control heads also go pretty frequently. My dad's 97 has a bad #4 position and the first thing I did is replace the resistor and I had no change.
So do some testing first to figure out where your problem is
Akkeith
Sep 15, 2011 11:20 AM
REDNECK.CADILLAC
Jan 22, 2010 11:08 AM
kkbodyshop
Jun 17, 2009 12:24 AM
daryl
Sep 10, 2008 04:32 AM
91boz
Aug 16, 2008 08:28 PM
