Help... oil filter mount
I'm screwed. First oil change. Factory had the filter on so tight. Filter wrench didn't work...crushed the filter. Tried the screwdriver trick.....tore the case so bad still tight. Finally got it off but due to my efforts, there is a gauge in the mating surface. I need this truck for a 400 mile trip tomorrow and oil is spraying out between the basket and mount. I need help fast.
Originally Posted by notop71
(Post 61346)
I'm screwed. First oil change. Factory had the filter on so tight. Filter wrench didn't work...crushed the filter. Tried the screwdriver trick.....tore the case so bad still tight. Finally got it off but due to my efforts, there is a gouge in the mating surface. I need this truck for a 400 mile trip tomorrow and oil is spraying out between the gasket and mount. I need help fast.
JB Weld . . but I don't want to drive it too long with this as a band aid. Any suggestions / help is mych appreciated!
