Hub install and seal replacement questions!
Hey guys, On my 98' Silverado, I am installing a new front hub into the knuckle and was wondering if anybody knew if the knuckle opening that the hub goes in needs to be clean or do I need to put grease in before the hub? Also how can I tell if the knuckle seal where the axle shaft comes through needs replacing? Thanks much!!
