Rear-Axle Question
Forgive me if this an obvious question, I'm new to this. What is the model rearend used in 2001 1/2 tons? I have a 1500 Sierra that has an open rear that i would like to upgrade.
There are several options, if you are able to look in your glovebox and find the list of three digit codes, look for the one of the following codes
GU2 2:73 ratio GU4 3:08 ratio GU5 3:23 ratio GU6 3:42 ratio GT4 3:73 ratio GT5 4:10 ratio GQ1 Open Differential Rear Axle G80 GOV-LOC Rear Axle Hopefully I understood your question correctly? |
Almost
That actually cleared up my next question, thanks for the info. But my original question concerned what model (dana 60, GM 12 bolt, Ford 9", etc.) the rear axle is so I order the right parts for it. Thanks!
