Ultimate Free Horsepower Mod List
Old Jun 26, 2007 | 07:52 PM
MrLM7's Avatar
Default Ultimate Free Horsepower Mod List
I started on this thread a long time ago, and I think some people on the forum havn't been on here long enough to see it... So here it is... can somebody say "STICKY"?
These mods are for the 99+ trucks/SUVs withV8 engines...
1. "Redneck Ram-Air"- Take your stock airbox out and cut many small holes to perforate (sp?) a large section to be cut out in the frontof the airbox(facing the headlight), under the joint where the filter sits. You can do this with an ordinary household drill anda hole-saw (like for cutting door-**** holes).... BE CAREFULL NOT TO CUT TOO CLOSE TO THE JOINT WHERE THE TOP PORTION OF THE AIRBOX ATTACHES!!!Make sure you clean out all the plastic shavings before reassembly. For best results,I highly recommend a high-flowdrop in air filter such as a K&N. I think Auto Zone sells them for around $50. These air filters are lifetime filters that you only clean when they need to be cleaned. When you go to the track (or around town), you can take the passenger side headlight out and have a free Ram-Air-ishsetup. It will help bring cool air in the engine (especially at highway speeds). Money saved-$300 compared to the Vera Ram system. Even more if compared to a ram air hood.
2. "Mass Air Flow Sensor ScreenRemoval"- To do this, you just loosen the clamps around the sensor with a flathead screwdriver, slide the tube to the side and then remove the sensor from the airbox. CAREFULLY unclip and remove theconnection. With the sensor screen side down, VERY CAREFULLY push the screen out with the end of something (Craftsman ratchet handle works well), MAKE SUE YOU DO NOT HIT THE SENSOR WIRES!!! People have seenunfavorable results from this modification by hitting the sensor wires!!!Put it back together and be sure to securely fasten the connection and air tube. Money saved- $300-compared to an aftermarket MAF sensor.
3. "Air Gap Manifold"- Locatedunderneath the throttle body,under the intake manifold and above the lifter valley,there is a little insulating pad that helps cold starting and warmup. In environments were this is not needed, it can be removed, it's your decision. Just unhook your intake hose from the throttle body, move it up and out of the way, and you'll see it. On the back side of your engine, there is another one. Just climb up there, reach around, and pull it out. This one won't come out as easily, but it's still not too hard. Next, remove your engine cover from the top of your engine. There is about 3/8" of insulation on the underside that is good for cold weather, but that's it. These can comeoff andgo backon andgo in and outany time you want.The cover has a bolt on the top and little clips on the back. Money saved- N/A, to the best of my knowledge, nobody makes an Air Gap manifold for the LS1 series engine.
4. "Throttle Body Coolant Bypass"- On the bottom side of your throttle body, there are two hoses. These hoses bring hot coolant through your throttle body and like the pads, assist in cold weather startup. Do you realize how much better your truck runs when it's cold, (temp gauge at or below 160)? When it gets warmed up, (gauge at 205-210), throttle resonse is greatly reduced. This mod wiil let you have that throttle response all the time.This mod DOES COST YOU ABOUT TEN DOLLARS. All you need is a 12" piece of steel brakeline, (I forget the size, but I remember it was two from the smallest this Auto Zone had.I've got the tag somewhere, though. If you need to know, just send me a message!!!), and two clamps that fit on those hoses (less than 1" diameter). Get the screw kind. Make
Old Jun 26, 2007 | 08:14 PM
smoke20's Avatar
Default RE: Ultimate Free Horsepower Mod List
All hail the king of free mods - MRLM7
Old Jun 26, 2007 | 09:47 PM
MrLM7's Avatar
I guess I'm good for something...
Old Jul 7, 2007 | 12:01 AM
MrLM7's Avatar
Bump
Old Jul 7, 2007 | 08:15 AM
72charger's Avatar
Won't removing the muffler make you lose torque? That is what two highly experienced techs I used to work with told me.
Also, in the "air gap manifold" you mention that we have an LS1 series engine..... I thought the LS1 was a 350ci that came in camaro, T/A, and the vette...
Also, is there really any benefit to the air gap manifold?
Old Jul 7, 2007 | 12:34 PM
chevy112488's Avatar
how big of a section should get cut out of the airbox? or does it matter?
Old Jul 7, 2007 | 02:34 PM
popo's Avatar
i turned the bottom section of my air box into swiss cheese with the drill and it turned out well
Old Jul 7, 2007 | 04:57 PM
stopspazinout's Avatar
originally yes the ls1 was a corvette/camaro 350 cid engine. but they brought it back in the new design that is 99 and newer.
Old Jul 8, 2007 | 10:34 AM
hunt4game29's Avatar
Postedsame thing 2 timei hatewhen it does that.
Old Jul 9, 2007 | 09:15 AM
Well i have the ram air and the tb bypass done now and the truck runs great.
