Help needed
Help needed
I have a 98 tacoma with 32" tires and I wanna get a lift real bad. I was wondering where I can find one the cheapest . I can put it on myself so I just need to know where to order one from . I'm lookin for a 3 to 3.5" suspension lift
Probably the cheapest way is to install Bilstein 5100 shocks set for the highest level. That will get you 2.5 inches. Or replace the coil springs like with OME 880 or 881 along with the 5100 shocks with the shock in the mid range clip setting and that combo will get you the 3 inches. Any higher and you will need to change the upper control arms other wise you will damage the upper ball joints. For the rear and keep your quality of ride you have just put in a 1 or 1 1/2 or 2 inch block. Talk to the people at Wheeler Off Road. Here is there web site. Old Man Emu Suspension for Toyota Tacoma Trucks- Wheeler's Off-Road, INC
Whitaker24
09-06-2011 08:13 PM
