1989 Toyota 4x4 fuel filter
hey I just got a 1989 Toyota 4x4 and would like to replace the fuel filter and i thought it would be in a similar spot as my 80's Celica but it isnt, anyone who can tell me where it is would be awesome.
RE: 1989 Toyota 4x4 fuel filter
check on the passenger side of the truck right behind the door on the fram rail under neith, its small so look.
Totato by4
He is correctvI owned and changed manu 89 fuel filtes. It is on the passenger side frame rail behind the XTRs cab if you have one. There is a permament housing that you open up and pop inthe new filter. Preferably use a flared wrench I had the pleasure oncr, but a reular wrench will work, it is pressureized so watch the eyes. I wish to hell I had the internet to help me. avgjoe |
It looks a little judging by the date of the post but just in case someone else cannot locate their fuel filter, on my 89 4runner it is located on the engine block above the starter on the passenger side,
i can see mine when i remove the small plate on the engine side of the fender |
The fuel filter is usually located at the passenger side frame rail behind the XTRs cab. try to check them out.
where can i turn the fuel off where i wont lose all the fuel i have in the tank??
