-   Toyota Tundra (https://www.truckforums.com/forum/toyota-tundra-22/)
-   -   2007-2013 Toyota Tundra 12' Lift Kit By Bulletproof Suspension (https://www.truckforums.com/forum/toyota-tundra-22/2007-2013-toyota-tundra-12-lift-kit-bulletproof-suspension-19703/)
nick_bp May 22, 2013 11:29 AM
Quick Overview:
http://www.bulletproofsuspension.net...e95/2/6/26.jpg
Fits 2007-2013 Toyota Tundra 2WD/4WD Regular/Double Cab & Crew Max short/long bed.
All parts are covered in high quality gloss black powder coat (color upgrades available).
Factory wheel base and track maintained.
Wear resistant urethane bushings.
Improved ride & handling from factory.
No drive shaft modifications required on 4WD applications.
No welding required and kit is designed to be entirely "bolt on"
All Bulletproof manufactured parts are covered by a lifetime transferable warranty.
BulletProof Suspension:
Looking to install 37-38" tires up to 13.5" wide on your 2007-2013 Toyota Tundra? Well look no further. Bulletproof Suspension Inc. has designed a 12" Suspension System with the best engineering and superior quality Bulletproof Suspension is recognized for. Our Bulletproof Suspension for Toyota Tundra system sets the bar for the industry. All components are made from A36 steel plate, 1/4" thick or thicker and heavy wall D.O.M.(drawn over mandrel) seamless steel tubing. We use continuous seam welding and our spindles are of box construction internally gusseted and rosette welded. Our Toyota kit for it's name sake is "Bulletproof".
To Find More Information Please Visit:
And Call to Us on:
909-389-0444
