Toyota Tundra Discuss the Toyota Tundra here.
Autel IM508 Adds 2018-2021 Toyota Fortuner 8A Blade Key
Old Aug 22, 2022 | 02:45 AM
Oswin's Avatar
Default Autel IM508 Adds 2018-2021 Toyota Fortuner 8A Blade Key
Here’s the guide on adding blade chip key ID8A 2017 2018 2019 2020 2021 Toyota Fortuner by Autel MaxiIM IM508.
Note: add key only. 8A blade key all keys lost requires 8A adapter. Smart key all keys lost requires 12-digit PIN.
Let’s get started.
Go to IMMO function- Toyota- Automatic selection
This function requires network connection
Select Immobilizer- Immobilizer H 8A/8E- Learn Key
Make sure you have a master ket. you must have a master key before clear or add another key.
Insert learned master key and turn on ignition switch
Remove key, insert key to be learned, and keep the ignition off
Leave the key in the ignition for 60s
Wait the lamp lights go out, learning succeeded
Test both keys.
Old Jun 10, 2024 | 07:42 AM
NioMarvin83's Avatar
Thanks for the guide! I’ve used the Autel IM508 to add keys to a couple of Toyota models myself. It’s pretty straightforward once you get the hang of it. Just make sure your network connection is stable, and having the master key is crucial. Had a similar process with my 2019 Fortuner and it worked like a charm. Good luck with your key programming!
Shawn Cooper
Apr 25, 2020 11:54 PM
geekgame818
Jul 11, 2012 03:23 AM
WaterLoo93
Jun 4, 2010 11:34 PM
Derekm162
Sep 23, 2007 08:55 PM
droptopfiveo
Aug 14, 2005 02:34 PM
