-   Toyota Tundra (https://www.truckforums.com/forum/toyota-tundra-22/)
-   -   Batery Churging Problems (https://www.truckforums.com/forum/toyota-tundra-22/batery-churging-problems-17852/)
valwatundra Nov 15, 2011 11:39 AM
When i start the tundra, on higher rpm's its allright
when rpm's are lower it shows batery sighn on and off, if i rave it a little sighn is off, after little wile dont matter how hard you rav it it does not churge the batery, at any time when i would unplog the batery cable truck would turn off
johntaps May 24, 2012 07:43 AM
Change the battery:)
nelsee Jul 28, 2012 01:31 AM
Your battery will be expired that is why such problem will be creating just change the battery.
Michaelleonel321 Sep 9, 2012 11:48 PM
Firstly make sure that all the cable's are fixed and attached properly or not loosened. If the problem still persist then there must be something wrong with your charger of battery.
jeslin_G Sep 13, 2012 07:15 AM
I think you should change your battery.
