2005 Chevy 1500 AC Intermittently works
Old 08-05-2010, 10:31 AM
bigox's Avatar
Default 2005 Chevy 1500 AC Intermittently works
Help!
My truck has a great AC when it works... but sometimes when I start it it won't make the compressor turn on, it just blows hot air. Then if I kill the engine and restart it it will then start cooling. What is going on here? is there a relay or contact that I need to replace? any suggestions would help. I know this has to be happening to others as I have another friend that has the same problem.
Old 08-05-2010, 12:27 PM
RUFFNECK4LYFE's Avatar
A/C Cycle switch is probably bad. Cheap part and this is very common.
Old 08-06-2010, 10:07 PM
DuramaxJunkie2005's Avatar
Default 2005 Chevy 2500 AC Intermittently works
Help my A/C does the same except I have dual climate control and the passenger side is cold as ever. What should I do?
Old 08-06-2010, 10:22 PM
chrisbmo2000's Avatar
Agreed.....the clutch cycling swith is probably bad.
flipsideafter
16
09-03-2020 07:41 PM
chevy112488
04-14-2010 09:50 PM
Lovemydiesel
01-24-2009 07:07 AM
jsh757
10
03-19-2008 07:44 PM
frankpeplinski
06-18-2007 04:40 PM
Quick Reply: 2005 Chevy 1500 AC Intermittently works
