high oil pressure
Old 11-04-2007, 10:27 PM
chevy112488's Avatar
Default high oil pressure
my oil pressure is 40 at idle, over 60 cruising at 70 mph... is this normal? it seems prettyhigh...
also, someone told me if i use 10w30 oil it wont burn off as much as 5w30... is this true?
Old 11-05-2007, 10:47 AM
Default RE: high oil pressure
That is what pressure mine runs.
Thicker oil will "blow by" less.....the thicker you get the more load on the motor....to thick and it won't climb the crank.
My mother runs 20w-50 in every vehicle she's ever had and they all made it to 250,000 miles. They still ran but she traded in for a newer vehicle.
Old 11-05-2007, 04:47 PM
I run the recomended 5w30, conventional 5w30, change it at 3000 miles, and it comes out just as clear as when i put it in, and it never burns a drop. good oil, good oil filter and good air filter help all of this.
Old 11-05-2007, 07:07 PM
yea that is what the pressure is suppose to be i thought my sending unit was bad then relized that was the spec for it
Old 11-05-2007, 09:28 PM
alright just checking, thanks guys
pappybarnett
02-22-2017 08:30 PM
Brennen beal
09-06-2012 08:21 PM
ElectroJoe
08-22-2011 03:21 PM
chief_22006
04-26-2010 10:16 PM
Ender06
06-09-2008 11:40 AM
Quick Reply: high oil pressure
