towing capacity
towing capacity
Does anybody know the limiting factor that makes the silverado 5.3 only able to tow 8900 lbs? Is it engine, tranny, brakes, axles, etc? I know I used to tow 12k all the time with my 93' silverado with no problem, but it was also rated for less. The new Ford comercial claims "fully boxed frame", but I know that is just a sales gimmic. Also if it is engine, then the capacity should go up with improvements right?
RE: towing capacity
boxed frame would be good for wheelin, but other than that its a sales thing, ive hailed 8k around the hills hereno problem with the stock 5.3l. i would bet the ford weights more so you might be able to stop quicker. chevy comes stock with load range c tires so thats probly a big factor 2,500per tire cap.my hitch says 500lbs max touge weight so a better hitch and maybe helper springs would be a good idea.
