2000 f350 7.3 starting issues
Old 04-17-2013, 04:17 PM
cgf95056's Avatar
Default 2000 f350 7.3 starting issues
Intermittently but becomming more often when i turn the key on everything powers up and glow plugs heat up. Turn to start and absolutely nothing happens as if it was totally dead (but it isnt) cause then if i turn the ignition on and off anywhere between 1 and several times something finally clicks and it turns over and starts as normal. Any ideas? I already replaced the starter solenoid. Thanks.
Old 04-17-2013, 10:32 PM
Sounds like it might be a dirty or loose connection.
Check and clean all your connections starting with your negative terminals on your batteries. Then your positive posts down to your starter.
Bob05
08-31-2014 07:23 AM
jrc0927
12-22-2010 11:35 PM
GMC83DUALLY
06-16-2010 06:42 AM
dryin
02-23-2010 07:23 PM
allenbowman4
09-22-2008 07:28 PM
Quick Reply: 2000 f350 7.3 starting issues
