GM How-To's and Tutorials Have a project you're working on? Take pictures and write up a procedure...We'll post it here!
OBD1 Codes "How to pull with code list"
Old 03-27-2010, 07:11 AM
Worf's Avatar
Default OBD1 Codes "How to pull with code list"
For vehicles made after 1996, retrieving the codes of the check engine light in your dash panel is simple. All you need to do is find your diagnostic connector located under the dash by the driver side. You can then hook up a scanner and the codes will be displayed for you. If you don't have any scanner like most drivers, you can bring your vehicle to any local automotive store and they will usually scan the codes FREE for you. However, for vehicles made on or before 1995, there is only one cheap way to get it: You do it yourself!
On board diagnostic (OBD) was designed on vehicles equipped with electronic fuel injection so you can generally retrieve the codes yourself. No need buying a scanner or running to any parts stores to check the engine light.
This system is called obd1 and applies to most vehicles made before 1995 for domestics and 1993 on imports.
For GM domestic vehicles made before 1995, the diagnostic connector is located under the dash panel by the driver side.
To get the check engine codes to flash in your dash panel, use a jumper wire or a paper clip and connect terminals A and B of the diagnostic connector. Turn your ignition key on with engine off and the codes should start to blink. All codes should start with code 12 which is one long flash followed by 2 short flashes.
This code 12 means the diagnostic system is normal and will repeat itself continuously if there are no trouble codes. Otherwise, code 12 will flash 3 times before flashing the fault codes.
Below are the OBD DTC's for 1995-previous model year EFI-equipped GM vehicles.
DTC - 12 No distributor reference pulse (diagnostic test active)
DTC - 13 Oxygen sensor circuit open or no activity
DTC - 13 Left bank O2 sensor circuit open or no activity
DTC - 14 Engine coolant temp sensor error (high temp indicated)
DTC - 15 Engine coolant temp sensor error (low temp indicated)
DTC - 16 System voltage too low
DTC - 17 Camshaft position sensor error
DTC - 21 Throttle Position sensor error (signal high)
DTC - 22 Throttle position sensor error (signal low)
DTC - 23 Intake air temp sensor error (low temp indicated)
DTC - 24 Vehicle speed sensor error (open circuit or no activity)
DTC - 25 Intake air temp sensor error (high temp indicated)
DTC - 26 Quad Driver Module (QDM A) error
DTC - 28 Auto transmission range pressure switch error
DTC - 31 Wastegate solenoid circuit error
DTC - 31 Gear Position Switch (PRNDL) error
DTC - 32 EGR system failure
DTC - 33 MAP sensor circuit error (signal high indicating low vacuum)
DTC - 34 MAP sensor circuit error (signal low indicating high vacuum)
DTC - 35 IAC problem or idle error
DTC - 36 MAF sensor error
DTC - 36 24x Crankshaft position sensor circuit error
DTC - 36 4T60-E Shifting Error
DTC - 37 TCC brake switch circuit error
DTC - 38 TCC brake switch circuit error
DTC - 39 Clutch switch circuit error
DTC - 39 TCC error
DTC - 41 Ignition control error
DTC - 41 MEM-CAL error
DTC - 41 C³I Cam Sensor Signal error
DTC - 42 Ignition bypass circuit error
DTC - 43 Knock sensor error
DTC - 44 Oxygen sensor error (lean condition indicated)
DTC - 44 Left bank O2 sensor error (lean condition indicated)
DTC - 45 Oxygen sensor error (rich condition indicated)
DTC - 45 Left bank O2 sensor error (rich condition indicated)
DTC - 46 Pass-Key II (VATS) system error - circuit out of freq range
DTC - 47 UART (serial data) circuit error
DTC - 51 PROM error
DTC - 51 Incorrect MEM-CAL
DTC - 52 Fuel cal-pak incorrect or missing
DTC - 53 System voltage too high
DTC - 53 Digital EGR Valve solenoid 1 error
DTC - 54 Fuel pump circuit low voltage
DTC - 54 Digital EGR Valve solenoid 2 error
DTC - 55 ECM error
DTC - 55 Digital EGR Valve solenoid 3 error
DTC - 56 Quad Driver Module (QDM B) error
DTC - 57 Boost Control error
DTC - 58 Trans fluid temp sensor circuit error (low voltage)
DTC - 58 VATS system error
DTC - 59 Trans fluid temp sensor circuit error (high voltage)
DTC - 61 A/C system performance
DTC - 63 Right bank O2 sensor circuit error
DTC - 63 MAP sensor circuit signal voltage high (low vacuum indicated)
DTC - 64 Right bank O2 sensor lean exhaust indicated
DTC - 64 MAP sensor circuit signal voltage low (high vacuum indicated)
DTC - 65 Right bank O2 sensor rich exhaust indicated
DTC - 66 A/C pressure sensor circuit error (low pressure indicated)
DTC - 67 A/C pressure sensor circuit error
DTC - 68 A/C clutch relay circuit error (shorted to ground)
DTC - 69 A/C clutch relay circuit error (open circuit indicated)
DTC - 69 A/C high pressure switch error
DTC - 70 A/C pressure sensor circuit error (high pressure indicated)
DTC - 71 A/C evaporator temp sensor circuit error (low temp indicated)
DTC - 72 VSS signal circuit error
DTC - 73 A/C evaporator temp sensor circuit error (high temp indicated)
DTC - 75 Digital EGR solenoid #1 circuit error
DTC - 76 Digital EGR solenoid #2 circuit error
DTC - 77 Digital EGR solenoid #3 circuit error
DTC - 79 Transmission fluid overtemp
DTC - 80 Transmission component slipping
DTC - 82 3x Crankshaft position sensor circuit error
DTC - 85 PROM error
DTC - 86 A/D error
DTC - 87 EEPROM error (flash memory error)
DTC - 90 TCC error
DTC - 93 Transmission pressure control solenoid circuit error
DTC - 96 Transmission system voltage low
DTC - 98 Invalid PCM program
DTC - 99 Invalid PCM program
I hope the above information helps you GM owners
Old 03-27-2010, 12:00 PM
chrisbmo2000's Avatar
Nice Post Viper.......you get a sticky........lol
Old 03-27-2010, 05:06 PM
Worf's Avatar
LOL thanks
Old 06-12-2011, 12:15 AM
cubpak89's Avatar
cool post worf
i have one question thow
if i am reading this correctly i can pull my codes without a scanner on my 94
but my questions is to you what do you mean by it should start flashing on your dash panel is that in referance to tnew vehical or older then 94
Old 06-12-2011, 10:51 AM
Your check engine light will flash. There will be a longer pause between the first and second digit. In other words if it flashes fast 3 times and then there is a longer pause and then it flashes fast 2 times that is a 32 code.
Old 06-12-2011, 12:07 PM
cubpak89's Avatar
ok i ge it know never knew thatbefore
thanks shamrock
ill be doin that with my truck today seeing what code comes on
Old 02-16-2012, 12:28 PM
wstd's Avatar
Hey, thanks for the information. This is really going to make troubleshooting easier (hopefully). One question though, this thread as well as the other information on scanning for codes using this method explain that code 12 should come up first, followed by trouble codes, followed by code 12. My sierra is putting out code 32, then code 12. I assume it's still working properly, but should it not be giving me a code 12 first? Could this be a sign of a problem with the ECM?
Old 05-09-2013, 10:38 PM
hellozaizai's Avatar
Banned
Old 06-04-2013, 10:59 PM
engeda's Avatar
Originally Posted by hellozaizai
thx for your code table
i just looking for it
Worf
Dodge/ Ram How-To's and Tutorials
06-30-2012 04:05 AM
DivotMaker
03-31-2011 01:32 PM
Worf
Ford How-To's and Tutorials
04-11-2010 04:56 AM
chevy112488
11
10-03-2007 07:49 AM
wade
04-23-2007 12:28 PM
Quick Reply: OBD1 Codes "How to pull with code list"
