-   Chevrolet Avalanche Forum (https://www.truckforums.com/forum/chevrolet-avalanche-forum-12/)
-   -   avalanche tryna cut off (https://www.truckforums.com/forum/chevrolet-avalanche-forum-12/avalanche-tryna-cut-off-13789/)
ablockag May 23, 2010 07:51 PM
i have a 2003 avalanche z71 it start up fine but every time i put it n drive it start to act as if its going to cut off on me then it start running back ok in like 30 seconds i changed the fuel filter thinking that was the problem when i start to drive it cut off before i can make the block but then start right up with no problem can any 1 help me.
Mr_Shamrock May 23, 2010 08:02 PM
When is the last time you had the throttle body cleaned?
ablockag May 23, 2010 08:04 PM
never i just gotten the truck how do i clean it i like to do my own work if i can
Mr_Shamrock May 23, 2010 08:25 PM
It's a very easy procedure. Just get an aerosol can of throttle body cleaner and take the intake tube off. You will see all the black carbon built up in there. Personally I like to remove the entire throttle body, but most people just clean them on the truck. A small toothbrush comes in handy for the tough stuff. Get it as clean as possible especially where the throttle blade meets the inner wall of the throttle body. Good luck and let us know how it works out for you.
ablockag May 23, 2010 08:36 PM
i will thanks alot i will get on it first thing tomorrow
ablockag May 24, 2010 09:06 PM
that wasnt the problem im thinking its my idle air control valve or its a bad sensor any1 want to put there in put into it
ablockag May 25, 2010 08:09 AM
ok i checked my throttle body it was clean same problem
Mr_Shamrock May 25, 2010 08:14 AM
I assume you don't have any codes popping up.
ablockag May 25, 2010 11:42 AM
not to my knowledge but how do i know if i have any codes my check engine light is not on
Mr_Shamrock May 25, 2010 04:09 PM
Does it work...when you turn the key on it comes on and turns back off?
