2005 GMC Sierra- NO REVERSE- neutral is drive- park does same as reverse
2005 GMC Sierra 2500 6.0 NO REVERSE- neutral is drive- park does same as reverse
changed filter and neutral safety switch with no luck.. when I put it in reverse or park it only revs up to 2000 rpm and just sits there like I have foot on brake. All forward gears work and neutral is non existent, it's now drive. When I put it in first gear it drives and continues to shift to other gears and when I let off it does slow right down at lower speed and jolt you forward as it should.. any one have any idea what the possible issue is?
94GMC45
11-26-2009 08:11 AM
RYDOG626
04-11-2009 03:34 PM
