-   Chevy/GMC Small Trucks Forum (https://www.truckforums.com/forum/chevy-gmc-small-trucks-forum-13/)
-   -   how about this problem (https://www.truckforums.com/forum/chevy-gmc-small-trucks-forum-13/how-about-problem-17095/)
juiser Jul 19, 2011 12:18 AM
:confused: I have 2000 Sonoma 4.3 Vortec . Started with engine cutting out and lacking in power upon acceleration, eventually followed by code for maf sensor drove for a while and progressively got worse till couldn't get no higher than 3000 rpms and unable to drive without cutting out, replaced maf sensor cleared code.No more code issues but still has same problem, replaced fuel filter no improvement any advice would be greatly appreciated.
In2Trux Jul 19, 2011 06:35 AM
Welcome to the forum Juicer
juiser Jul 20, 2011 12:22 AM
glad to aboard
Thank for the reception, hope to learn as well as help.:)
Mr_Shamrock Jul 20, 2011 07:01 AM
Welcome - check your fuel pressure first. It could also be the spider injection - I would pull the plugs to see what they look like. A couple of them are real fun in the S-10's.
juiser Jul 20, 2011 03:23 PM
I had put new spark plugs in al ready before this happened will check any ways to see if fouled up but starts perfectly, also do you check fuel pressure with appropiate guage at the Schrader valve above the fuel inlet .I have a CSEFI system on this 4.3. The book I have gives a spec of 55 to 61 psi with key on engine not running and should decrease by 3 to 10 psi at idle.
juiser Aug 2, 2011 12:54 AM
:) Just wanted to give an update on this issue ended up being cat converter was plugged. disconnected ran perfect put on universal cat runs excellent, thank you for all the help people!
