Chevy/GMC Small Trucks Forum Discuss the Colorado, Canyon, Sonoma, S-10, etc here!
Ignition Module
Old Jun 9, 2007 | 01:41 AM
czbill's Avatar
Default Ignition Module
I have a '92 S-10 Sonoma with 51,000 original miles. It is a 4.3 V-6, 5 speed standard transmission, extended cab. Has A/C, PB & PS and not miuch else. Every 4-6 month the truck starts running a little rough, even with the A/C off. After about a week or so of this, it won't start, cranks fine but no spark and no TBI fuel being injected. On rare occasions, such as yesterday, I can let the truck sit for a couple of hours, and after moving and fiddlng with the two module connections, the truck will start. It made it home, stalling twice but restarting. Today it won't start for anything no matter what is done to the connectors.
Every time this happens, I install a new ignition module and everything is fine for another few months. This is a problem of the last two years or so, before it was perfect. I have replaced 4 modules in the last 18 months.
The plugs are relatively new, the wires the same. Have run the truck at night with the hood up, don't see any sparks or lights. The ignition module connectors have been cleaned and lubricated, they are tight when installed. The proper grease is used under the module, it is tightened evenly and snugly, but not overtightened.
Does anyone have a similar experience or see something I am missing?
Thanks.
Old Jun 9, 2007 | 06:10 AM
Argon's Avatar
Default RE: Ignition Module
Is it a delco module?..these jap modules (which borg warner is as well) are junk..
you can make SURE its the module test lite and some patience...I have no idea of your tools/mech knowledge,but its pretty simple.
key on
unplug 4-wire connector at ,module...leave 2 wire connected
pull a plug wire off and install a spark checker
watch your tbi injectors
attatch the test lite to B+
look at your connector...there is a purple wire.....MOMENTARILY touch the purple terminal with your lite
the spark should jump once and the injectors will give a shot of fuel..
If that does happen,then you know your ecm,coil,pole piece.cap,rotor,injectors,wiring are all good...it HAS to be the module.
Old Jun 9, 2007 | 12:43 PM
czbill's Avatar
Thanks for the suggestions. I will certainly check the module as you said. Since the truck is my work truck and I work out of the country, it is real inconvenient when it dies. All the parts here are Chinese replacement parts. I am at the stage of going to GM and simply buying everything new, coil, pickup coil, module, wires, plugs, distributer cap, rotor. At least then I will be starting with a clean slate. Just replaced the alternator in December, so that should be good and is not a common factor for all the failures.
shop2011
Sep 8, 2011 12:40 PM
mpyrol
Mar 9, 2008 04:37 PM
spidyrmen
Aug 21, 2007 04:44 PM
SoylentGreen
Jul 17, 2007 07:48 PM
dpriceis
Jan 2, 2007 10:18 PM
