09 front end noise.
Old Jan 12, 2014 | 09:18 AM
Locotech007's Avatar
Default 09 front end noise.
09 Sierra SLE. extend. cab 4x4. 5.3 flexfuel eng.
After last weeks cold snap, a groaning crunching noise comin' from front end. Have Service traction control, service stabilitrak, warnings as well as ABS light on. First thought it was snow and ice build up in the front end, but that's not the case. Headed to dealer on Mon. Just lookin' for ideas what it might be.
Old Jan 12, 2014 | 05:21 PM
NullHead's Avatar
Maybe blowed up the front axle. Does it make the noise when you're in 4x4 or 2wd?
Maybe an ABS wire was broken or something. The groaning might be from the ABS being activated or something like that ... would have to pull all the codes to see what's going on.
Old Jan 12, 2014 | 07:38 PM
Noise front end could be a number of things... Wheel hub bearing causing your ABS modual to become misaligned.
Old Jan 12, 2014 | 10:16 PM
thanks guys, it does it for about 2-3 minutes when you first start to drive, in 4 or 2 wheel drive. After the initial couple minutes it seems normal, but I still get the warnings. Got rid of a 23 yr. old Toyota for this, maybe I shouldn't have....lol.
Old Jan 21, 2014 | 06:07 PM
Default problem solved
Thanks for the replies guys. It was a right front hub/bearing assembly and ABS sensor.
Old Jan 21, 2014 | 09:09 PM
NullHead's Avatar
Sweet! Thanks for coming back and letting us know.
Did you end up changing it out on your own, or did you take it somewhere for service?
Old Jan 23, 2014 | 08:40 PM
lol, real sweet, was covered under the extended warranty.
gmcchevylover
Mar 2, 2009 09:03 AM
atmracing7032
Dec 7, 2008 06:17 PM
thatguy_2_2
Feb 26, 2008 03:02 AM
popo
13
Feb 18, 2008 07:43 PM
benpfeil
Apr 19, 2007 11:33 PM
