Front end noise
Old Mar 21, 2007 | 01:17 PM
benpfeil's Avatar
Default Front end noise
I have this really odd noise in my front end. It comes from the drivers side and only when I'm driving in town. The noise appears at 30 and goes away at 40. Its a howling noise and I can't seem to figure it out cause its only in the speed range. Any ideas?
Old Mar 21, 2007 | 03:43 PM
03TEXASEDITION's Avatar
Default RE: Front end noise
Did you change your tires or do any other mods to the exterior of your truck? Howling generaly comes from the wind blowing across a surface in a weird way.
Old Mar 21, 2007 | 08:18 PM
smoke20's Avatar
is it 2 or 4wd? could be the front drive shaft spinning as if not fully disengaging.
Old Mar 22, 2007 | 01:25 AM
benpfeil's Avatar
Truck is a 4 wheel drive. I have made many changes but its made the noise before I did these. I've had 2 other sets of wheels besides the factory's and with all of them the noise is still there. But the weirdest part is its only in that 10 mph band.
Old Apr 19, 2007 | 10:23 PM
Ridge Runner's Avatar
I got the same thing going on with the 2004 Z71 4WD that I just bought. It only has 35000 miles on it so hope it is something simple. Sounds just like the noise you get when you rub your finger around the top of a wet crystal class. It comes in at about 25 mph and goes away at 40 mph. Driving me nuts. I am about ready to take it back to the dealer and let him listen to it. Any suggestions??
Old Apr 19, 2007 | 11:33 PM
smoke20's Avatar
ridge runner - have you tried rocking your truck by hand when sitting still? I had a squeaking noise in mine when moving at speed but not going slow. Ended up being the shock bushings in the front end. started around 25-30k miles
pak_racing
Mar 14, 2009 09:46 AM
gmcchevylover
Mar 2, 2009 09:03 AM
atmracing7032
Dec 7, 2008 06:17 PM
thatguy_2_2
Feb 26, 2008 03:02 AM
popo
13
Feb 18, 2008 07:43 PM
