14’ GMC SIERRA 1500 6.2L intermittent rattling accelerating
Old May 10, 2021 | 03:44 PM
BIGNickHenry's Avatar
Default 14’ GMC SIERRA 1500 6.2L intermittent rattling accelerating
I have a 2014 GMC Sierra 1500 SLT double cab with the 6.2L. Recently noticed a hollow sounding metallic rattle. Almost like a vibrating heat shield. It is very hard to reproduce; however most commonly occurs after truck has been running for some time and goes from 0-30 mph. If you let off the gas when it’s occurring it will stop but usually only last for a couple seconds anyways.
I’ve checked all my heat shielding, U joints, exhaust mounts, and other obvious things you could just by getting under there and inspecting things. Differentials should be good; I changed oil and inspect a few thousand ago. Popped the 3/4 socket plug out and stuck finger in and still nice and golden without a bunch of shavings. My only guess could be a catalytic converter perhaps that when heated will rattle some? The truck still drives great no slipping of gears or loss of power when this sound occurs.
VIDEO OF SOUND:
Last edited by BIGNickHenry; May 10, 2021 at 03:53 PM. Reason: ADDED LINK TO VIDEO OF SOUND
Old Jun 29, 2021 | 05:54 PM
alfuller72's Avatar
Default Sierra 6.2 Rattle
VIDEO OF SOUND: https://youtu.be/9mdYMsc1mqc
Hey Nick did you ever find the source of the rattle in your Sierra? I am experiencing the same issue and searching for answers. Any input is much appreciated. Thanks
Old Jul 14, 2021 | 03:46 PM
justinre's Avatar
Default Exhaust
I have been having this same noise for over a year. I should take it in, but I dont want to spend hundreds to troubleshoot it. Please tell me someone found out something on this. Mine sounds just like this.
Old Jul 14, 2021 | 03:48 PM
justinre's Avatar
Have you figured anything out?
Old Jul 14, 2021 | 06:30 PM
alfuller72's Avatar
Default Resolution to Rattle
I added a tube of shutter fix to the transmission fluid. It worked immediatly. I havent had any issues. Everything is nice and quiet.
Old Nov 26, 2024 | 03:35 PM
Jwilly1763's Avatar
Default Rattle
Nick, I have the same rattle. I've had various exhaust pieces removed and replaced by pipe: flex joint, small converter, and the flap door behind the muffler. No luck. Did you find a fix for yours?
mcboo_Sierra
Sep 28, 2009 06:18 PM
GMCGirl
Apr 23, 2009 02:47 PM
lowrider_62
Mar 23, 2008 11:39 AM
xtmsports
Oct 19, 2007 06:31 PM
Kswood
Jul 9, 2007 09:24 AM
