1987 sierra cruise I.D. for dummy
Just got a 1987 gmc sierra and am trying to identify if this truck was originally equipped with cruise control. It appears to have a aftermarket (newer) turn signal without the cruise button in the end of it, but under the hood there are "extra" accessories that have me wondering. So, for the dummy here, can someone please tell me what parts to look for that are strickly cruise control related so that I can determine if this truck was originally cruise equipped.
Or maybe breaking down the vin would help reveal this info???? thanks for the help |
Do you still have the rpo code sticker in the glove box?
there is a "service parts identification" sticker; is this the 'rpo' sticker?
Originally Posted by sraey8
(Post 69061)
if you see the service parts identification look a little more to the right of it and it should be in there but if there not then the previous owner may or may not have replaced the glove box |
So looks like no rpo sticker in box; what next?
well im not really sure of how to tell if it was sposed to have cruise or not but for that year it may have been an option but not on your particular truck also check on the driver side engine firewall there should be a black box with a cable running to the carb that is your throttle cable
im not for certain if your year of truck has this or not it may just have a cable running from the gas pedal to the carb |
will check; anything else under hood to look for ? or maybe something as simple as a cruise control fuse in fuse block ?
Just shooting in the dark here; all guidance accepted. |
this is a long shot on your truck but do you have the owners manual or did it not come with one
also there mybe a cruise fuse under the dash or hood remove your fuse panel cover and look on there it should have a description or abrivation of what fuse goes where and what not it also may be under the fuse itself in real small lettering the reason i ask if you have the owners manual is there is also a page with fuse locations in it there is a website called compnine.com it will tell you what your truck came with write down your vin on a paper or whaterever go to the website go to the reasearch on the right side of the page go to vin identification it will tell you alot about your truck ps thanks shamrock for that cool website |
Owners manual says that cruise control would be routed through a 20a Ign. fuse, along with 6 other things. So yes, there is a 20 amp ign. fuse, but this isn't really answering the cruise equipped question.
Any other suggestions? |
well if ya wanted i would say go under your dash and look for wires that arent connected to anything
but i really dont know how to tell on that year of truck if you have a mechanicaly inclined friend or buddy have them take a look at it or even take it to a local mechanic and ask them the simple question it never hurts to ask let us know how it goes |
| All times are GMT -5. The time now is 07:35 AM. |
