1989 chev 1500 no dash lights, but taillights
Old Nov 22, 2010 | 08:04 PM
otis332's Avatar
Default 1989 chev 1500 no dash lights, but taillights
I am a new owner to a 1989 Chev 1500. It has no dash lights at all. when the lights are off, the fan indicator for the heat/air is on. When the head lights are turned on the light goes off and there are no dash lights either. I do have brake lights and turn signal lights. I was told it was probably my dash dimmer switch. Any suggestions?
Old Nov 28, 2010 | 08:07 PM
Ezrider_92356's Avatar
Member
i agree with the dimmer switch, try rolling the dimmer switch back and fort and see if if they flash on at all a lot of times the pots get dirty and will work momentary while adjusting them. but even if they don't flash on it does not necessarily rule it outs
Old Nov 30, 2010 | 07:02 PM
chevychase's Avatar
Loosing ground , When you turn on head lights , it is taking a weak ground away from the dash light. Check your ground wires. Maybe run a new ground to dash lights.
dimmuborgir6nik6
21
May 12, 2023 03:58 PM
cubpak89
May 16, 2011 11:37 PM
Shorted
Jan 4, 2011 09:22 AM
kletuspse11
Jun 13, 2007 04:28 AM
judykevans
Aug 15, 2005 06:51 PM
