1989 GMC - 5.7: Fuel Supply TBI Fitting Gasket
Old Apr 7, 2012 | 11:09 AM
rodeonav's Avatar
Default 1989 GMC - 5.7: Fuel Supply TBI Fitting Gasket
Help. Anybody know the part number and where to source. Need a Teflon
flat gasket (seal) that fits on the end of the GM fuel inlet fitting. The seal interfaces with the TBI and fitting - which in turn fits the Saginaw 16mm x 1.5 fuel line fitting. I've found a GM kit called "Nut kit with gaskets" that contains both the inlet and return fittings - both with the Teflon gaskets in question.
The kit lists for $25 to $48. All I need is the gasket - probably a 10 cent part. Guess if nobody has a part number to source the gasket - I'll spend the dough and buy the kit. Thanks In Advance for any HELP!
dearborn2415
Oct 25, 2011 03:45 PM
swearingsailor69
16
Nov 26, 2010 08:19 PM
patrickhutsler
Jan 19, 2010 05:35 PM
Thraxxx
Oct 22, 2007 04:31 PM
stopspazinout
14
Jul 1, 2007 04:04 PM
