1990 chevy 1500 driverside break light is out
Old May 4, 2008 | 11:43 AM
brotherblood's Avatar
Default 1990 chevy 1500 driverside break light is out
i have a 1990 chevy 1500 silverado and only the driver sidebreak light is out. Ive replaced the bulb, and checked the fuses, replaced the contact plate and still can not figure out why i cant get it to work correctly. Now the reverse lights dont want to work and the blinker lights dont blink anymore they only stay on constantly. Use to be the break light would work sometimes but now it never works anymore only the passanger side break light works. Does anyone have any suggestions??
Old May 4, 2008 | 12:03 PM
Chevycowboy's Avatar
Default RE: 1990 chevy 1500 driverside break light is out
Have you tested the wire?
Old May 4, 2008 | 12:10 PM
No i havent, would i just use a voltmeter to do that? Also what would make the reverse lighs not come on, nor the signal lights work correctly?
Old May 4, 2008 | 12:16 PM
It could be a number of things, I've only had similar problems with a trailer setup and I ended up just replacing it all. Yes, you can use a handheld multimeter with the resistance setting selected. If you see numbers or hear a beep(depending on the model) your good.
dragonfly
Aug 11, 2012 01:16 AM
Z0sizzle
Oct 22, 2010 08:20 PM
farmboy91
Mar 15, 2010 08:38 PM
TJsierra1500
Feb 24, 2010 08:11 AM
pipefitterdan
Dec 24, 2006 07:40 PM
