1991 C1500 5.7 Issues
Old Jan 10, 2013 | 03:33 PM
acquarossa's Avatar
Default 1991 C1500 5.7 Issues
Hey guys, new to the forum and hope im posting in the right area!
I had been having an issue with my truck where it would get massive fuel cut (bucking and hesitation) when in overdrive on the freeway, a slightly rough idle (would idle fine and have random hesitations, not consistent at all). Check engine light never came on so i did the usual; oil change, air filter, fuel filter, cleaned out the throttle body to no avail.
Now as of a couple days ago im getting terrible idle, and absolutely no power. feels like im driving a go kart! the service engine light came on for about an hr, then went off again.
Found a few websites that talked about not having to get a code reader and just jumping the terminals. im 99.9% sure i jumped the correct terminals but when i put the key in the on position the service engine light just flashes once then stays on.
the only other thing i can think of is when its idling really rough if i put it in neutral it idles better (not perfect, but better)
Any insight would be greatly appreciated!
Old Jan 10, 2013 | 05:10 PM
RustyFordLover's Avatar
Possibly a intake manifold Gasket. That engine had quite a bit of trouble with that going out and causing problems.
Welcome to Truck Forums.
Old Jan 11, 2013 | 06:34 PM
acquarossa's Avatar
gah i hope not. thats one of those repairs where its only a $15 dollar part but takes hours to do if ya dont know what you're doing...which i dont. This is my first chevy, and first 8cyl engine so a lot of this stuff is pretty new to me.
Old Jan 12, 2013 | 02:27 AM
I can have the whole job done in about 45 mins. It's not that hard to do.
Old Jan 12, 2013 | 10:57 AM
I would suggest getting the codes read. Try and find a place that can do a LIVE code reading too
It sounds like your truck is creating issues that are temperature sensitive
Please come back and let us know what you learned
Old Jan 13, 2013 | 07:31 AM
Diesel Dan's Avatar
X2 on what In2Trux said.
You have a CEL on, have the code pulled first.
Very common issue on those is cap/rotor corrsion internally.
Don't just throw those parts on it unless they are bad, you need the computer scanned.
Old Jan 13, 2013 | 10:35 AM
acquarossa's Avatar
The cel was only on for about an hour. Does it store old codes when the cel goes off? I tried jumping the two terminals but it didn't flash any codes.
Old Jan 13, 2013 | 04:04 PM
I have never had any luck reading codes on anything. I don't even mess with it any more.
Old Jan 13, 2013 | 06:22 PM
Your ECM will have a history. The technician can search throw the history to find related codes and faults
Old Jan 14, 2013 | 07:59 AM
Diesel Dan's Avatar
Those early ECMs don't store all codes.
Sometimes they only show certain codes while the CEL is on. When jumping terminal A-B on the ALDL if the CEL won't flash code 12 it indicates a bad ECM. That is assuming the data link has a good connection with the ECM.
bck4more
Jun 16, 2014 06:36 PM
StevieLee
Mar 14, 2011 09:08 PM
zeroglider
Apr 20, 2009 05:12 AM
rebeltaz
May 15, 2006 10:40 PM
drhino
May 4, 2006 03:24 PM
