1994 c1500
im having problems with a 1994 chevy c1500 the mods done to the truck are vortec heads edelbrock 3702 cam headers holley 670cfm throttle body with gm injector pod with 350 injectors tbichips custom chip i have been working on the truck for a few months and it runs rich no matter what we try it fouls the plugs can anyone help
I would contact tbi chips to see what they say. You probably need an adjustable pressure regulator with that set-up though. What intake are you running? Are all sensors still in place?
1994 c1500
brian at tbichips is helping me to find the problem i want to see if there are more people they may be able to help im running a performance products cyclone vortec intake manifold
I did a similar swap years ago and I remember I initially had spark plug issues. I was running the wrong ones. Are you running the plugs that are recommended for your truck or for the vortec heads? I can't remember which way I ended up having to go, but I know it was real gutless with the wrong ones in it.
1994 c1500
using plugs for vortec heads ac delco r44lts
I can't remember but that sounds right, but I would verify just in case. Hopefully TBI chips can get you right. I did mine before the internet had all these forums and never knew about the custom chips needless to say it never ran near at what its potential was. I am not even sure if the custom chips were even around. If I remember correctly it was in 99 or 2000.
1994 c1500
i think i may have found part of the problem with the engine there are bubbles in the radiator and the radiator builds pressure with just a few minutes of running the engine is missing bad at idle its not running hot there is no water in the oil so i dont understand it the engine has about 150 miles on it and never ran hot
1994 stock 1500 4.3
hey,I have a tiny leak at the fitting in the rear of the intake manifold where the quick connect for the heater hose is,I have all the parts in hand,but was wondering what to do if that fitting breaks off in the manifold.Im told by the dealer parts guy that almost always happens
:mad: |
