1997 keeps blowing fuse
Old Jan 18, 2009 | 05:36 PM
tan1320's Avatar
Default 1997 keeps blowing fuse
My 1977 K1500 keeps blowing the #9 fuse that operates the parking lights and the dash lights I have replaced the headlight switch and the plug that went to it for it was burned. Any body have any Ideas for I am at a loss
Old Jan 19, 2009 | 09:54 AM
rxsteven's Avatar
Default RE: 1997 keeps blowing fuse
I'd hit the bone yard andand get a used plug and splice it in.
Old Jan 19, 2009 | 10:39 AM
tan1320's Avatar
Already have replaced plug and it still blows the fuse
Old Jan 19, 2009 | 07:04 PM
acnas's Avatar
Have you changed any bulbs lately? Seen wires get pinched in the lens clips when put back together.
Old Jan 20, 2009 | 12:08 AM
Steven's Avatar
that was happening to me also and all i had to do was change the thing that does the brightness levels and havent blown a fuse since
Old Jan 20, 2009 | 05:57 AM
tan1320's Avatar
No I haven't replaced the bulbs but I have checked the circuit board that they are plugged into
Old Jan 20, 2009 | 07:54 AM
chrisbmo2000's Avatar
you obviously have a direct short to ground........check the turn signal switch and the brake light switch I found one on my 97 that the wire had burned completly off the turn signal switch.....Ive got a schematic if you need more info let me know
Old Jan 20, 2009 | 08:44 AM
tan1320's Avatar
I could use a wiring schematic and I will check the turn signal switch and brake light switchthis thing is driving me nuts
Old Jan 20, 2009 | 11:25 AM
try this link for the schematic: http://www.autozone.com/shopping/rep...00c1528008f3ce I use these alot, let me know if you need more help
Old Jan 23, 2009 | 06:00 AM
tan1320's Avatar
Have checked turn signal and brake switch no burnt wires but I am still blowing fuses
