1997 silverado 5.7 whistle squeak front end at idle
Hi,
I have a very annoying squeak or whistle coming from the front of engine. It is worse at idle only starting after the engine is warm. I have changed the fan clutch and the ac pulley. I thought it was the fan clutch for sure, when I notice that after the engine is shut off the whistle or squeak continues after the belt stops. Now I think the whistle is air intake related??? Any ideas what could be the problem? Thanks for your help. |
check your vacum lines as there might be a leak in them or as you said it could be an intake leak i guess but i cant see it being that after you shut the engine off
also it could be yoru radiator cap realeaseing pressure slowly |
