2001 4.8L idle is intermittent
Old May 24, 2009 | 08:58 AM
jbens's Avatar
Default 2001 4.8L idle is intermittent
I read a number of threads but nothing sounded exactly like what I am dealing with. A couple times a week I will jump in my truck in the morning and drive to work and it starts just fine and in the afternoon when I start it, it starts just fine but will not idle and quit. I turn the key again and it will start but will not idle. I then turn the key with my foot on the gas and I have one foot on the gas and one on the brakes. I drive for 15 minutes and then everything is fine.... I had the 100K tune-up 6-7 months ago. I don't want to take it into the shop and pay for a diagnostic and have them tell me they don't know what is going on... any help would be much appreciated.
Old May 24, 2009 | 10:38 AM
RUFFNECK4LYFE's Avatar
Idle Air Control Valve. Take the throttle body off the manifold and then take the IAC valve off and lookat the pintle tip. It will probably have some grime on it. Try to move the pintle in and out very gently to make sure it is not siezed. It may just need cleaning on the tip. Here is a video of how too...
Old May 24, 2009 | 04:37 PM
jbens's Avatar
Thank you ruffneck. I will see if I can get to that this weekend.
Old May 24, 2009 | 04:52 PM
Welcome!! Let us know the results.
Old May 25, 2009 | 08:54 AM
timber74wolf's Avatar
Also try cleaning the butterfly at teh opening of your throttle body. Your senario sounds just like what my grandmother's 01 Chevy silverado did, but with a 5.3. I cleaned all the gunk off the biutterfly and blew throttle body cleaner all in the throttle body let it soak for a bit and cranked her up... No problems now.
Old May 26, 2009 | 08:34 AM
jbens's Avatar
Thanks wolf. That sounds easy and I might try that first.
Old May 27, 2009 | 10:07 AM
Jwahoo's Avatar
Default Same idle problem as Jbens
I am experiencing the same problem with my 2000 GMC Sierra Z71 (5.3 ltr) as described in Jbens' posting. The same procedure was used as described with holding the brake with one foot and the accelerator with the other foot to hold the engine at idle speed (about 500 rpm). While on a trip out of town, I took the truck to a dealership. First trip: cleaned throttle body and installed new air filter ($138.58). Next day same problem: took to dealership -- they replaced the Idle Air Control Motor (probably the same as Idle Speed Control) at a cost of $235.93. After returning to my home city, the truck stayed parked for 3 days. Yesterday when I started the truck, it has the same problem.
Old May 27, 2009 | 04:09 PM
Are you sure they cleaned the butterfly at teh opening of the throttle body? Remove your air ducting and look to be sure there is no black gunk caked up around the edge and the small circular opening of the butterfly. If it is indeed clean then look for play in the butterfly rod that holds it. I read somewhere that teh rod or bearings/ bushing develope slack/ slop and can cause the same problem. I will try to find that thread...
Old May 27, 2009 | 04:50 PM
I can not find the thread I was looking for, but maybe someone will recall it and point you in the right direction as to what I am talking about when it comes to the throttle body rod that holds the butterfly.
fury58426
Oct 29, 2006 08:51 PM
Fred
Sep 19, 2006 11:49 PM
investor
Sep 17, 2006 03:06 AM
odqlesz
Sep 15, 2006 12:31 PM
badsgt
May 3, 2006 03:08 PM
