2001 silverado 1500 4.3 2 wheel drive
I have replaced a lot of parts to include plugs,wires fuel pump fuel pressure regulator,alternator,battery,temp sensor...It has been dying when warm out of no where, we pressure tested and it is 55, and we are getting good sparks..Any ideas? thanks JOHN
RE: 2001 silverado 1500 4.3 2 wheel drive
does it start right back up?...was the pressure 55 when it died?
After the truck got towed to friends house, we fuel pressure tested it at 55, and it was getting good spark, then after sitting awhile, it fired back up..Now last week was the first time for this but it did this after I filled up..Got on the highway,thend it just sputtered out.I pulled over ,and with in 5 minutes I was back on the road.So yesterday I was driving, stopped at a store came out wouldn't start , friend came,probably cause the truck had cooled off a bit, it started back up, but couldn't make it home as it sputtered out again. My friend who does his best work on european cars thought maybe the crank modulater.
The truck does have a new oem fuel pump, and we replaced the spider looking fuel lines under neath the truck.
well,its losing spark or fuel pressure...your gonna have to find out which is missing when its dead...its a crapshoot otherwise
wow, when it cools off for few it cranks right back up, and when it died there was 55 in fuel pressure, and we got pleanty of spark, but when it first sputtered out it was like bad gas, then at a store it wouldn't crank then about 5 min, it cranked after cooling a bit. I have a 1/4 tank left of gas..COULD IT BE THE CRANK MODULE/SENSOR? thanks John
so much eaiser to explaine over phone, I would make the call so there was no cost to you ...John
well,no..the ignition module is fine if you have spark WHEN ITS DEAD
did you check the fuel pressure WHILE ITS DEAD? i betcha its a pump...spark problems are so rare on these engines |
yes, and the fuel pressure was 55, my friend thinks it is fuel electric related, like a relay I have a brand new fuel pump and we replaced the fuel lines under the truck asd the was a crack in the line
fuel pressure is 55 when dead so my friend says we are getting fuel, hes thinks maybe electric fuel related like a relay? again he does his best work on european cars
