2001 Silverado Z-71 Multi Function Switch / BCM Problem
Old Oct 15, 2009 | 07:33 PM
EGT1's Avatar
Exclamation 2001 Silverado Z-71 Multi Function Switch / BCM Problem
HELP!
I have a 2001 Silverado Z-71. Several years ago my headlights started flickering and I found the trouble in a broken wire on the Multi Function Switch wiring harness where it plugs to the MFS. I repaired the broken wire and it's worked great until last week. The headlights went out again so again I looked at the MFS and found that the wire I repaired plus one more next to it were burned, slightly melting the wiring harness connector. Splicing new wires didn't work so I bought and installed a new MFS which came with a new wiring harness. Still no headlights and now I have no interior lights, no under hood light, no cargo light, the key remote wont work the door locks AND the truck wont start!
I have an MT2500 scan tool (Snapon brand) that will communicate with all vehicle functions except the Body Control Module. I think that I may need to reprogram the BCM or buy a new one. I retreived one DTS code, P1626 Vehicle Theft Deterent, so the truck is in lock down (turning off the injectors).
Has anyone had this problem? My Chevy dealer is stumped (which is usual for them) and I don't want to tow my truck to them so they can keep it for a month a charge me $2000.
Old Oct 17, 2009 | 07:28 AM
redbone's Avatar
Member
im not sure how to help with your problem. but could you direct me to where the mfs is i think im having the same problem.
Old Oct 18, 2009 | 05:14 PM
EGT1's Avatar
It's attached to the turn signal lever, mounted on the steering column.
Old Oct 23, 2009 | 08:03 AM
redbone's Avatar
Member
How hard are they to get to? i priced a new one its $189. does that sound right? The old problem of having no brakelights fixed itself and they started working for a couple days then out of nowhere i have no passenger tail light/turn signal/brake light on the rear and the cab I havent checked to see if my reverse light works on the passenger side yet. Everything on the driver side works fine.??
hawks
Oct 7, 2008 03:15 PM
Joneebgood
Mar 16, 2008 12:23 PM
plantro
Feb 24, 2007 03:19 AM
amanbg
Dec 23, 2006 01:11 AM
