2003 Silverado Fan Problrm
Old Nov 24, 2007 | 07:55 PM
tomzx79's Avatar
Default 2003 Silverado Fan Problrm
My heater fan only works on speed 3 and up. It will not work on lower speed. Has anyone had this problem?
Thanks,
Tom
Old Nov 24, 2007 | 10:02 PM
Tankfxr's Avatar
Default RE: 2003 Silverado Fan Problrm
I had a problem similar to this on my 95 Z ended up replacing the fan motor and something else. I cant remember what it was called and it was hard to get to. It had something to do with temprature sensing and it was under the dasn near the fan mounted in the "duct work" of the a/c/heater.
Old Nov 25, 2007 | 05:19 AM
Argon's Avatar
its the a/c resistor MOST LIKELY....but could be the switch...
if the resistor plug is melted,you'll need a resistor and a connector
Old Nov 25, 2007 | 10:19 AM
racethisz71's Avatar
its the blower motor resistor its very very commen for those to go bad on any car
Old Nov 26, 2007 | 09:45 AM
Gary's Avatar
Argon
Where is the resistor and connector?
Old Nov 26, 2007 | 06:04 PM
Argon's Avatar
on the right floorboard....loadred trucks have a panel that hides the a/c box...cheaper truicks do not..
look uynder there...you'll see the round fan motor...left of that is the resistor,with a big plug with about 7 colored wires....unplug that and see if the end is melted
Old Nov 26, 2007 | 06:42 PM
Z71TwoTone's Avatar
A buddy of mine's 06' burned to the ground because he didn't fix that melted plug.
Old Nov 27, 2007 | 08:39 AM
Gary's Avatar
Thanx Argon
I'm on a road trip in the Smokies.. will check it out..
when I get home & let ya know how it turns out
duckhunter5
Aug 9, 2014 08:27 PM
digger
Oct 9, 2008 04:21 PM
a_tack
Feb 25, 2007 03:13 PM
Foxracingmxz69
Feb 6, 2007 10:41 PM
kfleeman
Oct 5, 2006 01:09 AM
