2003 Silverado Heater Problem
Old Feb 14, 2010 | 10:12 AM
acrtech's Avatar
Default 2003 Silverado Heater Problem
Hi, new guy on the block. Just bought my 2003 Silverado. The heater only works when I set heater to manual and 90 degrees. I can control heat pretty good by cycling the fan speeds but if you set tem to say 70 degrees heat doesn't work. Has anyone else had this problem. I looked at the diagrams and found indoor and outdoor sensors but it doesn't show where they are located. If you put it in auto , the heat wont work even is set at 90. Any help will be appreciated.
Old Feb 15, 2010 | 07:57 AM
acrtech's Avatar
I saw on a post that this guy had the same problem with his 2003 and no one knew what caused the heater problem. He said almost exactly the same as the post above.
twotone
Aug 18, 2011 09:09 PM
s2micha
Dec 14, 2010 07:38 PM
spearfisher
Jan 22, 2010 12:20 PM
Z71
Aug 3, 2008 08:47 PM
Moparmick
May 21, 2008 04:19 AM
