2005 Silverado misfire & lean
Old May 9, 2012 | 12:16 PM
Bourbon Legend's Avatar
Default 2005 Silverado misfire & lean
First off just wanted to say thanks, been lurking here for a while and found some great info. Now for the problem.
2005 Silverado, Ext. Cab Z71, 5.3L, 131,000 miles. About a year ago while changing the spark plugs, I broke 1 (bank 2 closest to the firewall), so I put the original back in and neglected to replace it until a few months ago when the CEL came on. Truck started idling rough with a misfire occurring during take off, but once it warmed up seem to run fine. Had the codes checked, P0300 & P0174. Found a loose plug wire, cleaned MAF, and replaced the bank 2 O2 sensors (lots of carbon build up on them)and it ran like a champ for about a week, then started up again. I figured it was time for the other side. Yesterday I replaced the bank 1 O2 sensors even though they didn't look too bad, problem persists. Checked the plugs: bank 1 fine, bank 2 not so fine, This morning I replaced them and checked the O2 sensors, and once again lots of build up. Since they were new I used a can of compressed air to clean off the build up. It seemed to run a little better, but CEL came back on on the way to work. Had the DTC's read and got P0300, P0174, and P0151. I'm gonna try putting the sensor from Bank 1 in place of the one in bank 2 now that the new plugs are in and see if that helps before I throw more parts at it, but I feel like I'm just chasing my own tail.
Old May 10, 2012 | 08:39 AM
Update-Swapped O2 sensor and Its running great again, but here's my new problem/question. When I pulled the old one there was a lot of oil on the outside and the inside of the connector. It was like this the first time I changed it too. I cleaned the contacts and used some electric connector grease to try and keep it from happening again. Anybody ever seen this before or know what might have caused it?
02bowtie
Apr 26, 2009 03:46 PM
edsz71
Mar 10, 2009 04:21 PM
JLusive425
May 15, 2008 05:13 AM
96burbo
Jul 23, 2007 05:19 PM
mr.algaz
Jan 31, 2007 05:32 PM
