2007 Silverado 1500 oil filter?
Old Oct 14, 2007 | 11:54 AM
dk1ben's Avatar
Default 2007 Silverado 1500 oil filter?
Ok so I have a new 2007 Silverado v8 5.3 crew cab 2wd. with active fuel management.
My father in law has suggested using Mobil1 oil and ACDelco filter. I dont question the oil choice. However shouldnt I use I higher quality filter. He claims that I much use ACDelco filter not to mess up my warrenty. Any thoughts?
Old Oct 14, 2007 | 01:54 PM
Tweaker's Avatar
Default RE: 2007 Silverado 1500 oil filter?
As long as the filter meets OEM demands then its fine. Ive been using Hastings filters for awhile and havent had a problem with the cheapies just gotta change them at their time.
Old Oct 14, 2007 | 02:53 PM
Argon's Avatar
A/c delco is best,cuz its designed for that engine..not just one that "fits"...
some others are probably ok...but make sure it has a check valve like the Delco,to keep the oil from draining back overnight
Old Oct 14, 2007 | 09:46 PM
JohnAdamsR's Avatar
Argon may be right but if you do get the Mobil1 filter it should be good. Those are some of the best (and most expensive) filters u can find.
Old Oct 14, 2007 | 10:58 PM
BlackHorse99's Avatar
a lot of people come into gm and get theire oil changed with mobil1, and we put ac delco filters on, 2007's run a pf48, in case you wanna know
Old Oct 15, 2007 | 12:10 PM
jcbst12's Avatar
At Advance we had a standard advance filter that was cut in half along with a FRAM Tough Guard filter that was cut in half, they were identical in design. The medium (filter material) might have been different, however. The Advance filter was only a couple of bucks and about 1/3 of the price of the FRAM Tough Guard. I was told to steer away from the basic FRAM filters and generic filters. I usually use Mobil1 or ACDelco.
weshod
Sep 21, 2010 01:44 AM
flycaster1
Sep 16, 2009 11:02 PM
Argon
15
Apr 11, 2008 02:55 PM
chevyrules
Jan 19, 2008 08:27 PM
vetteboy86
Feb 2, 2007 11:27 AM
