20s or 22s
i got an 05 sierra 2wd. im gunna put summer rims on.. im not sure if i can put 22s on with low pro tires and have good clearance so i dont get any rubbing when i turn.. i think 20s look good on the sierras. but i saw a tahoe today with stock 20s and they just looked small on such a big rig.. so if i get rubbing ill just throw on some 20s and be satisfied
The rubbing only occurs when turning. Some folks have put some wheel spacers to fix that but its risky. Its a bigger wheel which means more weight and stress on the hub with the spacer.
yeah.. im not spacing the rim.. its a stock offset of +38 but putting aftermarket rims the offset cant be more than +20 ive been told without spacers.. spacers are just more **** to loosen and things to go wrong..
If your at factory height you should have no problems running 22's. Depends on your budget of course.
budgets not the problem at all.. thanks coolrado
