20s or 22s
Old Mar 20, 2010 | 01:50 AM
drewitt16's Avatar
Default 20s or 22s
i got an 05 sierra 2wd. im gunna put summer rims on.. im not sure if i can put 22s on with low pro tires and have good clearance so i dont get any rubbing when i turn.. i think 20s look good on the sierras. but i saw a tahoe today with stock 20s and they just looked small on such a big rig.. so if i get rubbing ill just throw on some 20s and be satisfied
Old Mar 21, 2010 | 05:46 PM
RUFFNECK4LYFE's Avatar
The rubbing only occurs when turning. Some folks have put some wheel spacers to fix that but its risky. Its a bigger wheel which means more weight and stress on the hub with the spacer.
Old Mar 21, 2010 | 10:33 PM
drewitt16's Avatar
yeah.. im not spacing the rim.. its a stock offset of +38 but putting aftermarket rims the offset cant be more than +20 ive been told without spacers.. spacers are just more **** to loosen and things to go wrong..
Old Mar 22, 2010 | 04:57 PM
Coolrado's Avatar
If your at factory height you should have no problems running 22's. Depends on your budget of course.
Old Mar 23, 2010 | 02:17 AM
drewitt16's Avatar
budgets not the problem at all.. thanks coolrado
